how to print this tube?
So I've designed a little holder for my dent brushes.
I can see these artifacts / seam on the outer wall, originating from retracts / z-lifts during layer change. Is this normal or how can this be avoided?
(note: every print shows this pattern, however when I change the seam position to 'aligned', the vertical seam is straight upwards, but still visible)
Thanks for any help - Stephan
Posted : 18/09/2017 10:58 pm
Re: how to print this tube?
Try setting the seam position to random.
Posted : 19/09/2017 1:43 am
Try a bit less retraction. And try without z hop.
Posted : 20/09/2017 7:19 pm
