how to diable pinda heating
gillis.h
(@gillis-h)
Is there a way to disable pinda heating prior to printing?
I don't know why my printer suddenly starts doing this. Before it only did it once in a while.
But now every single print i have to wait 2 minutes before it starts. An issue if you want to quickly test things.
Respondido : 28/10/2017 9:54 pm
AJS
 AJS
(@ajs)
Re: how to diable pinda heating
This behavior is controlled in you slicer, not the printer. Your slicer has a section for "start gcode" which tells the printer what to do before sending the file to the printer. You can alter its behavior there.
Respondido : 28/10/2017 11:38 pm
gillis.h
(@gillis-h)
Ok. i thought about that. But what gcode line is responsible for the pinda heating?
for example if i look at my print settings in cura i see
G21 ; set units to millimeters
G90 ; use absolute positioning
M82 ; absolute extrusion mode
M104 S{material_print_temperature} ; set extruder temp
M140 S{material_bed_temperature} ; set bed temp
M190 S{material_bed_temperature} ; wait for bed temp
M109 S{material_print_temperature} ; wait for extruder temp
G80 ; mesh bed leveling
G92 E0.0 ; reset extruder distance position
G1 Y-3.0 F1000.0 ; go outside print area
G1 X100.0 E21.5 F1000.0 ; intro line
I don't see anything related to the pinda probe.
Any idea?
Respondido : 28/10/2017 11:53 pm
gillis.h
(@gillis-h)
Also. i don't think it is part of the gcode,
because even with the provided samples from prusa i am getting the heating pinda thing first.
Respondido : 29/10/2017 12:31 am
walter.l
(@walter-l)
I think you can turn this off in the printer menu, calibration/temperature calibration.
Respondido : 29/10/2017 12:58 am
1 les gusta
rocket kittens
(@rocket-kittens)
The PINDA probe does not perform any heating, it is a sensor.
https://en.wikipedia.org/wiki/Inductive_sensor
The resistor inside the nozzle heatblock and the heatbed are the only components that perform heating, both of which are required.
Why would you want to disable heating?
Respondido : 03/11/2017 7:57 am
Colin
(@colin-4)
There is a routine in the firmware where the pinda is held right above the heated heat bed for a couple of minutes before the Z calibration to heat it up and theoretically get a more accurate calibration, as heat affects the pinda's sensitivity.
Turn it off in the calibration menu in the printer.
--C
Respondido : 04/11/2017 3:08 pm
1 les gusta
