How much adjustment in live Z?
In order to get the v2calibration gcode to adhere, I have to go to almost -.900 in the live adjust menu.. Is this normal or should I adjust the probe itself at that point?
Opublikowany : 11/06/2016 10:54 am
Re: How much adjustment in live Z?
Keep the bed and hotend cold. Put plastic ruler on the bed to protect its surface. Move Z axis down by menu commands until the nozzle slithly touches the ruler. Adjust the nozzle so its about 1-2mm above the surface of the ruler. Then do calibration steps again.
Opublikowany : 11/06/2016 11:17 am
Depends completely on how high you have set the probe itself. 🙂
I have -1mm on live z adjustment and that works perfectly for me.
//Anders
Opublikowany : 11/06/2016 11:58 am
