Help Thermal Bed Runaway
Kevin
(@kevin-10)
I got a Thermal Bed Runaway tonight on my 2S and now it refuses to heat higher than 32 degrees. Any help greatly appreciated.
Veröffentlicht : 07/12/2017 8:49 am
alexander.s27
(@alexander-s27)
Re: Help Thermal Bed Runaway
Check whether the temp sensor still is attached tight to the bed.
I would bet it came loose and is kind of hanging around under the bed....
Veröffentlicht : 07/12/2017 11:39 am
Kevin
(@kevin-10)
That is it, exactly. Thanks. Is there anywhere that I can find where and how it is attached? I bought this already assembled, so I do not have an assembly manual and could not seem to find one on the website. I probably just don't where to look. Thanks. Many thanks.
Kevin
Veröffentlicht : 07/12/2017 8:21 pm
alexander.s27
(@alexander-s27)
It is just taped to the bed with some heat resistant sticky tape.
For printers we mostly like to use the so called KAPTON-tape.
For short time use or immediate needs the blue painters tape many use for the print bed surface might as well do the trick....
Assembly instructions are to be found here.... http://manual.prusa3d.com/#_ga=2.264583178.445681374.1511283210-1651111952.1499016096
Veröffentlicht : 07/12/2017 8:50 pm
Kevin
(@kevin-10)
Thank you for your help. You solved the problem.
Veröffentlicht : 08/12/2017 8:29 am
