heater bed mounting holes not aligned
stephen.c2
(@stephen-c2)
I have an issue with the y carriage centre holes not aligning with the heater bed, the heater bed nuts are off by approx 0.75mm. The four corner holes are fine, but at the moment I have no way of locking the y belt holder down to the carriage, its basically being held by tension and the fact the belt stops the screws falling out!
And yes the bed is on the right way round.
The image is rotated, the top is actually on the right.
Publié : 09/09/2016 5:54 pm
Ben
 Ben
(@ben)
Re: heater bed mounting holes not aligned
There is a note in the assembly instructions that the dot must be in a specific place. Did you note that small dot?
I think that makes a difference to the lining up of the heat bed 😉
Publié : 09/09/2016 6:46 pm
Ben
 Ben
(@ben)
Check step 11 and 13 here
http://manual.prusa3d.com/Guide/2.+Y-axis+assembly/104
Publié : 09/09/2016 6:51 pm
stephen.c2
(@stephen-c2)
Yep mine is on the bearing side rather than shown, I'll try that thanks.
Publié : 09/09/2016 7:02 pm
stephen.c2
(@stephen-c2)
That was the problem, everything lines up and solid now, re-running calibration. Thanks ben.b
Publié : 09/09/2016 7:27 pm
Ben
 Ben
(@ben)
Nice one. Glad you are now up and running. Happy printing 😉
Publié : 09/09/2016 7:32 pm
