Heated bed connector coming loose
andy.b
(@andy-b)
The connector from the heated bed to the RAMBO board keeps coming loose. I tried going back to printing in silence mode to reduce vibrations but it keeps happening. Any tips to keep this connector seated on the board?
Publié : 10/12/2016 2:36 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Heated bed connector coming loose
Andy
It should not come loose if you have the cable management correct and in accordance with the manual. Without seeing any pictures, I would guess you have a cable tie or two either missing, loose or in the wrong place.
Peter
Publié : 10/12/2016 11:11 am
andy.b
(@andy-b)
I'll try and get some pictures uploaded, but it has been printing fine for 5 months and it doesn't seem like anything is pulling on it. The connector comes just loose enough not to make a connection.
Publié : 10/12/2016 12:28 pm
david.b14
(@david-b14)
Would a zip tie going into the two bottom screw holes be of any benefit?
Publié : 10/12/2016 12:32 pm
andy.b
(@andy-b)
The zip tie may work, I'll have to take a look
Publié : 10/12/2016 12:42 pm
andy.b
(@andy-b)
I think I found the issue.
Publié : 10/12/2016 6:27 pm
