Heatbed heat not turning off
jason.l5
(@jason-l5)
I'm using the 3.0.9 firmware and on occasion, the print will finish, the nozzle temperature is at room temperature (off), but the heatbed is still heating(on). I can see that the LED on the heatbed is lit. If I press the reset button, the heatbed LED turns off and it returns to room temperature. Has anyone else seen this?
Postato : 02/11/2016 3:43 am
jason.l5
(@jason-l5)
Re: Heatbed heat not turning off
Ok, I think I figured out the problem. In Slic3r, I had set the Printer to 'default'. When you do this, it doesn't use the custom G codes to turn off the heatbed (among many other things like printing the intro line). So the moral of the story is to make sure to select the Prusa i3 MK2 with Zhop (or ColorPrint) . . . not 'default'.
Postato : 02/11/2016 5:17 am
