[FW 3.0.11] Temperature Calibration Inconsistencies
javier.c3
(@javier-c3)
Hi All!
I'm having some weird behavior with the new temperature calibration.
Since the new update my live-z values are completely different between the heatbed @55C and @100C.
@55C my live z is -.47
@100C my live z is -.9
Maybe the FW is overcompensating for the PINDA temperature deviation?
This happen to be dangerous for the PEI sheet since when I switched from ABS to PLA my heatbed got scratched because of the live z being completely off.
Anyone else is having this problem?
Respondido : 28/05/2017 9:35 pm
JeffJordan
(@jeffjordan)
Miembro Moderator
Re: [FW 3.0.11] Temperature Calibration Inconsistencies
hi javier,
do you use the temperature compensation inside an enclosure, or with an open printer ?
i guess the temperature of the probe didn't reach the target temperature when the printer starts to do the 9-point calibration.
at all, i'm not very convinced about the temperature compensation inside the new firmware. to do a proper temperature compensation you need to know the exact temperature of the probe... which you can - in my mind - only achieve with an additional temperature sensor at the probe.
the problem might be less severe when printing inside an enclosure, but will still persist.
Respondido : 28/05/2017 10:09 pm
javier.c3
(@javier-c3)
I don't use an enclosure but the ambient temperature isn't changing that much.
But it's fall over here so I think the room is a little bit cold.
Nevertheless the compensation is way off... Maybe It's because when calibrating the probe is getting warmer for a longer time between the 5 temp but that doesn't make any sense also.
Respondido : 28/05/2017 10:58 pm
