First own print with Prusa Slicer failed
andreas.e3
(@andreas-e3)
Hi guys,
i did the assembly of my new Prusa i3 mk2s this week and printed some parts from the sd-card, which worked pretty good.
Now I wanted to print my first own part, but it failed because the surface becomes more and more raugh (see attachments).
Does anyone knows what the solution of this issue could be?
Thanks!!
Veröffentlicht : 03/05/2017 12:45 pm
Mario
(@mario)
Re: First own print with Prusa Slicer failed
On the top right there are three dropdowns. Are you sure you picked the correct values?
Try "0.20mm NORMAL" as the print setting and "Prusa PLA 1.75mm" as filament. Printer should be "Original Prusa i3 MK2 with ZHop".
Did you adjust any other values? Might be wrong, but this looks like the extruder is pushing out too much filament and the nozzle then digs through it.
If the provided files printed fine, the hardware itself should be okay.
Veröffentlicht : 04/05/2017 9:07 am
