First failure, and the blob from hell
Bill
 Bill
(@bill-3)
I had seen other posts about the filament blob from hell and I hoped I never wound up with one. Well, the blob has arrived. 😥
I was printing this https://www.thingiverse.com/thing:1366605 and I discovered it could really use a raft since it turned loose from the bed after about 6 layers or so. I was asleep so I did not discover it until I had the model handing from the extruder head along with a blob.
Fortunately I have a precision heat gun for surface mount soldering. But, I would guess I should remove the E3D print head BEFORE applying heat??? Seams I could damage printer parts if I do not.
Thanks. 😥 😥
Opublikowany : 27/05/2017 7:36 pm
BallisticPanda
(@ballisticpanda)
Re: First failure, and the blob from hell
Hopefully your PINDA survived the failure. Be extra careful not to damage the probe while you exhume the extruder from its molten prison.
Opublikowany : 30/05/2017 6:43 am
