Extruder Temperature Fluctuation
Matt
 Matt
(@matt-11)
Hey everyone, I am new to the group. We received our original Prusa i3 MK2 a week ago and are completely impressed. We did run into a problem, I was having some issue with horizontal striations and noticed the extruder temperature cycling through a wide temperature range. For a model printing at 210c the extruder temp would cycle from 205 to 218c. My other printers normally stay within +- 2 degrees. I was doing some reading and found that inconsistent temp can introduce the horizontal striations. Does anyone know if there a setting to reduce the temperature cycle range?
Publié : 09/09/2017 4:27 pm
AJS
 AJS
(@ajs)
Re: Extruder Temperature Fluctuation
In the latest firmware there is a PID calibration which will measure how quickly your nozzle hits and cools and will use that in the control algorithm (PID) and will keep the temperature much more stable.
Publié : 09/09/2017 4:47 pm
Matt
 Matt
(@matt-11)
Thank you Aaron, based off your response I found the PID Tuning instructions. After running through these instruction it is rack solid on the printing temp. Worst case is 1 degree +-. Here is the link to the instructions for anyone else that might need it.
http://help.prusa3d.com/mk2-firmware/pid-tuning-hotend
Publié : 11/09/2017 12:49 am
