extruder motor jumping
charlie.g
(@charlie-g)
my machine is only a few weeks old and it has developed a problem were you can hear the extruder jumping or slipping, this leads to a gap in the line on the print.
I have tried adjusting the tension however it still seams to do it (this is using pla) I have tried a few different rolls of filliment but get the same result.
if I apply a little pressure to help feed the filament this stops it
any ideas?
Veröffentlicht : 20/08/2017 11:02 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: extruder motor jumping
A few possible causes:
Dirty filament drive pulley
Spool not turning smoothly
Filament twisted on spool
Bad tension setting
Partially blocked nozzle
Damaged PTFE tube
Temperature insufficient
Peter
Veröffentlicht : 20/08/2017 12:22 pm
MoreDots
(@moredots)
check while printing if it is slipping or stuttering.
if it is stuttering, you might wanna check out this topic:
http://shop.prusa3d.com/forum/original-prusa-i3-mk2-f23/extruder-feed-problem-t2892-s40.html
Veröffentlicht : 21/08/2017 10:25 am
charlie.g
(@charlie-g)
it looks like the motor is turning smoothly but every so often the motor slips on the filament like the filament cant go through fast enough. if I help feed the filament in with a little pressure it stops, the drive pulley looks in good shape, I have not changed any temp settings but it is starting to cool down here in the uk a small amount to when I built it. how can you tell if the nozel is blocked?
Veröffentlicht : 22/08/2017 9:22 am
