extruder motor jumping
my machine is only a few weeks old and it has developed a problem were you can hear the extruder jumping or slipping, this leads to a gap in the line on the print.
I have tried adjusting the tension however it still seams to do it (this is using pla) I have tried a few different rolls of filliment but get the same result.
if I apply a little pressure to help feed the filament this stops it
any ideas?
Re: extruder motor jumping
A few possible causes:
Dirty filament drive pulley
Spool not turning smoothly
Filament twisted on spool
Bad tension setting
Partially blocked nozzle
Damaged PTFE tube
Temperature insufficient
Peter
check while printing if it is slipping or stuttering.
if it is stuttering, you might wanna check out this topic:
 http://shop.prusa3d.com/forum/original-prusa-i3-mk2-f23/extruder-feed-problem-t2892-s40.html
it looks like the motor is turning smoothly but every so often the motor slips on the filament like the filament cant go through fast enough. if I help feed the filament in with a little pressure it stops, the drive pulley looks in good shape, I have not changed any temp settings but it is starting to cool down here in the uk a small amount to when I built it. how can you tell if the nozel is blocked?
