[Closed] Extruder feed problem
Stránka 4 / 4
Pathaf65
(@pathaf65)
Re: Extruder feed problem
HI!
I also have the same problem with prints stopping in the middle. I know there already is some descriptive posts on this so I don´t go in to details but will ad to the post for some explaination from Prusa or even better a solution.
I have a Prusa MK2s
>>Patrik
Napsal : 28/03/2018 6:41 pm
Matti Malo
(@matti-malo)
I have the same problems with PLA, silver and red. Someone was writing, that PLA can "crystallize" in high temperature. This seems to be correct. Many were reporting, that this is happening when printing small area, so filament is longer time in a extruder.
When I clean extruder, especially the silicon tube, the filament is thick. I measured it and got more than 2 mm (2,2). This has happened many times.
Now I am printing 10 degrees lower temperature of extruder and also the bed. Until now there has not been problems.
So, some PLA have problems, some of them no. Can Prusa do something for the material?
Napsal : 18/12/2018 4:37 pm
Stránka 4 / 4
