Extruder body is clogged. What to do next?
manuel.s5
(@manuel-s5)
Hello everyone,
Recently, my extruder clogged during a print. I was printed woodfill PLA from Colorfabb. So far, I have removed what I could of the filament and have opened the hatch and cleaned the pulley. Then, I checked the nozzle and removed and cleaned it as well. I removed as much material as possible from the nozzle and inserted the acupuncture needle and it went through with no problems. Tried loading filament again and it will not go through. I checked the extruder body from the bottom (nozzle end) with the nozzle removed and tried poking through with a needle and it seems clogged. The needle will not go through. I tried heating up (230 C) the extruder body with the fan removed to perhaps melt the material but nothing happened. Now, i think the next step is to remove the extruder body and take it apart and clean it. So, my questions are: 1) has anyone done this before? 2) what are the steps to remove the extruder body without damaging the printer/wiring? and lastly, 3) how do you know/recognize if the extruder needs to be replaced?
Any help or advice would be much appreciate it. Thank you in advance!
M.
Napsal : 24/05/2017 3:24 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Extruder body is clogged. What to do next?
Manuel
The extruder assembly manual can be found here: https://wiki.e3d-online.com/wiki/E3D-v6_Assembly Simply reverse the process.
You will not need a new extruder, but you may need replacement PTFE if that gets damaged during removal. You may also take the opportunity to swap the nozzle.
The blockage is most likely in the small gap between heat break and PTFE tube, so once the tube is removed applying a little heat to the heat break should get things moving.
The blockage was most likely caused by retraction value exceeding 1mm, but there are other reasons.
Peter
Napsal : 24/05/2017 7:53 am
MikeO
(@mikeo)
This happened to me a LOT when trying to print Brassfill.
Take the whole extruder apart. You will see where the blockage is. For me it was usually in the metal heatbreak just where it stayed cool - this is why heating it won't clear the blockage - it is above the hot bit!
I think it is frequent retraction, combined with slow overall extrusion, which causes this. Printing Brassfill in big solid areas worked fine because the molten filament was quickly carried away from the head. In small areas, with infill, or jumping from spot to spot, the extrusion slows and the heat travels back up the (metal in my case) filament, melting it at a much higher point than usual. When that melted bit gets retracted into the cold heatbreak or PTFE tube, it goes solid and ta da! Blocked.
You can use Acetone to disolve ABS if that's what you are printing with. I think I used a drill bit in the heatbreak in the end to slowly cut out the filament, by hand. The E3D heatbreaks are not always so smooth on the interior (as Prusa seem to have found when testing the MM upgrade). Hopefully your PTFE is ok, but its easy to replace. I ordered a second heatbreak, nozzle and more PTFE from E3D here in UK - that gave me a whole spare set so I could immediately fit a clean set and keep printing while I spent time sorting out the clogged one.
You should not need to replace the heater block, nozzle or extruder body (finned). But repeatedly taking apart the hot end can easily cause damage to your thermistor and heater, so you might well want to get spares of them too while you are at it. I fitted a connector in the thermistor cable so I never had to remove it from the heater block - but the movement has broken the teeny weeny wires anyway in the end. Wish they were not so delicate...
Good luck 🙂
Napsal : 24/05/2017 11:26 am
PJR
 PJR
(@pjr)
Usually heating does work with the extruder fan removed; after a while the heat will pass up the heat break and start to soften the blockage.
No that's usually fine; it's only when you use retraction settings of more than 1mm (or 0.8mm) and you haven't modified the PTFE tube and/or the lower end is not perfectly square.
Very bad idea. The inside of hte heat break is polished so that the filament will not stick. Inserting a hard, sharp object can easily damage the internal polish.
There was occasionally a small ridge at the point where the two drillings met, but the main reason was lack of internal chamfer and the gap between heat break and PTFE (retractions are much greater with Bowden tubes).
You will probably still need to modify the PTFE if you intend to use larger retraction.
Yes, it can, but I have been changing nozzles about every 2 to 3 weeks for the past 2 years (dusty environment - because it's quicker and easier than trying to clean) and have never had any problems with cables. Probably because I am usually very careful!
Peter
Napsal : 24/05/2017 12:47 pm
manuel.s5
(@manuel-s5)
@Peter, I followed your advice and you were right. The clogging occurred in the heat break body. I tried heating up the heat break but could get all of the PLA out.
@mike.o, thanks for the description on how it can get clogged. I think that is what happened. I ended up using a thin drill head to remove the rest of the PLA out of the heat break. I was very careful and it worked.
Thank you both for the advice. It really helped and I learned a lot by disassembling the extruder apart. For next time, I will have spare pieces just in case something breaks.
Napsal : 24/05/2017 11:08 pm
Jo Jaquinta
(@jo-jaquinta)
Same issue. I didn't find the official PRUSA documentation very helpful. Here you can see step by step what I did to clean up the issue. You'll need Allyn keys, needle nose pliers, needle nose tweezers, compressed air, fresh PTFE tube and some patience.
(Apologies for the image rotations. This forum doesn't seem to support CSS)
Here I've opened up the idler door. The screws are on the left side of the extruder while the idler door opens on the right
[attachment=2]20180618_215005[1].jpg[/attachment]
Here's a close up of the damaged PTFE tube and the offending filament.
[attachment=1]20180618_215452[1].jpg[/attachment]
Here you can see what needs to be replaced - the damaged PTFE tube better,
[attachment=0]20180618_220837[2].jpg[/attachment]
Did I mention that I had to remove a 45mm slug of filament?
Good luck!
Winky42
Freerange PRUSA evangelist
"All good things come to those who wait."
Napsal : 19/06/2018 4:43 am
Jo Jaquinta
(@jo-jaquinta)
[attachment=0]20180618_220844[1].jpg[/attachment]
Winky42
Napsal : 19/06/2018 5:15 am
