Error while upgrading to 3.0.9
andreas.s2
(@andreas-s2)
I got an error while upgrading the firmware
Uncaught node.js Error
Error: EROFS, open './fw.hex' at Error (native)
Can someone help me?
I am using a Mac with Sierra installed.
Opublikowany : 29/01/2017 3:24 pm
andreas.s2
(@andreas-s2)
Re: Error while upgrading to 3.0.9
Does no one has an answer to this problem?
Opublikowany : 30/01/2017 5:32 pm
andy.b
(@andy-b)
I had a similar issue, but rebooting the computer fixed it for me.
Opublikowany : 31/01/2017 2:00 am
andy.b
(@andy-b)
Here is another thread where people had a similar issue and different solutions:
https://shop.prusa3d.com/forum/original-prusa-i3-mk2-f23/firmwareupdater-crashes-with-uncaught-node-js-erro-t2084-s10.html
Opublikowany : 31/01/2017 2:03 am
e2erin
(@e2erin)
Dont know if you found the answer to this or not. I had the same problem with my mac. I had to move BOTH the .hex file and the firmware updater to the SD card the instructions say this: "It's necessary to have firmware *.hex file on the same drive as FirmwareUpdater application!"
Once I got them both onto the SD card the firmware updated just fine.
Opublikowany : 17/02/2017 4:31 am
Josef Průša
(@josef-prusa)
Member Admin
Can you try updated version for OSX Sierra? http://www.prusa3d.com/downloads/firmware/firmware_updater_v2_1_b.zip
They changed some privileges and it broke the updater :-/ but we found a workaround!
Founder and owner / Majitel a zakladatel
Opublikowany : 23/02/2017 5:49 pm
sheetzam
(@sheetzam)
2.1 worked for me, updated without a problem on the latest Mac OS.
Opublikowany : 24/02/2017 12:55 am
