Error Message After Replacing Print Sheet
David Bershad
(@david-bershad)
I replaced the pei sheet after it was damaged. After replacing the print sheet I ran the xyz calibration because nothing was sticking. When I ran the calibration a message, “XYZ calibration comprimised. Front calibration points not reachable.” appeared, what should I do?
Publié : 07/02/2018 9:51 pm
MechLink
(@mechlink)
Re: Error Message After Replacing Print Sheet
Hi, You can check to make sure nothing is stopping the X or Y axis from moving all the way to the end-stops and to there max range of movement
without something stopping or putting them in a bind.
To do this either turn off steppers or turn power off to printer and
slowly move each axis from the end-stop all the way to the other side of the axis range,
If you feel a drag or a hesitation near the end check to see if something is blocking it,
Such as the idler pulley on the Y-axis miss align and putting the belt in a bind.
When I re-did mine I had a issue with one of the bed u-bolts miss aligned from the slot that prevented it from reaching the sensor.
Also I like to reset the "Live-Z" back to Zero(0.000) before running the calibration for safety (just my opinion though).
See my stuff at
https://www.printables.com/@MechLink
https://www.myminifactory.com/users/MechLink
Publié : 07/02/2018 11:01 pm
