Drivers 1.9.0 with Slic3r Prusa Edition
Jakub Dolezal
(@jakub-dolezal)
Membre Admin
UPDATE: This package is no longer the latest, more here: https://shop.prusa3d.com/forum/original-prusa-i3-mk2-f23/drivers-1-9-2-with-slic3r-pe-and-prusacontrol-t6838.html
Hi there,
this is the newest release of drivers and software for your printer. Included is the latest stable release of Slic3r Prusa Edition. For newcomers to 3D printing is prepared another slicer PrusaControl, but keep in mind it is still in beta.
What is new?
Slic3r PE - updated to 1.37.1
PrusaControl - updated to 0.9.3_390_beta (with support for Multi Material)
Multi Material - new 3 material test object added – Big Whale Jumping by GabirelYun (uses PLA and BVOH)
Multi Material - new print settings for 0.6mm nozzle
Multi Material - printer tests all used extruders prior to the print on the first layer at the front of the print bed to verify proper filament insertion.
Supported printers:
This driver's package includes latest profiles for MK1, MK2/S as well as their Multi Material upgraded versions.
Download link: http://www.prusa3d.com/drivers
Slic3r PE full changelog: https://github.com/prusa3d/Slic3r/releases/tag/version_1.37.1
PrusaControl homepage: https://prusacontrol.org
How to install drivers on MacOS: http://manual.prusa3d.com/Guide/Installing+Slic3r+Prusa+Edition+-+macOS/404
Assembly manuals
/ Knowledge Base
Publié : 22/09/2017 12:27 pm
Vic
 Vic
(@vic-3)
Re: Drivers 1.9.0 with Slic3r Prusa Edition
Why is this being posted today since it was released since the 17? This throws us off.
Publié : 23/09/2017 4:09 am
Jakub Dolezal
(@jakub-dolezal)
Membre Admin
Hi Victor,
this post is to inform users about the latest available drivers and also place for discussion or bug reporting. I'm sorry for the delay I had a lot of things to do (mostly with MK3), in future I will do my best to share the info asap 😉
Assembly manuals
/ Knowledge Base
Publié : 23/09/2017 10:53 pm
carl.b2
(@carl-b2)
I tried to upgrade my firmware and I cannot find the hex fill. Did you forget to put it in the folder?
Publié : 25/09/2017 12:37 am
tim.h3
(@tim-h3)
I see that there's a new stable release out for both the firmware and slic3r.
Any hint when the rollup package will be posted?
I already loaded the new firmware and manually downloaded the zip for slic3r, but slic3r setup is a little annoying/underdocumented from github.
The new version of slicer still creates a 190 settings folder.
Publié : 14/11/2017 8:26 pm
Jakub Dolezal
(@jakub-dolezal)
Membre Admin
Hi Carl,
the firmware is not included in the package, you need to download it from here: https://www.prusa3d.com/drivers
Assembly manuals
/ Knowledge Base
Publié : 30/11/2017 9:17 pm
Jakub Dolezal
(@jakub-dolezal)
Membre Admin
Please have a look on our pages, latest package was just posted https://www.prusa3d.com/drivers
Assembly manuals
/ Knowledge Base
Publié : 30/11/2017 9:22 pm
