Do I have a bad Rambo board?
JLTX
 JLTX
(@jltx)
I have a new MK2S and it prints great! But I have noticed when I first turn it on with no inputs or adjustments I can hear very quiet whispery whine. If I let it sit there for a bit I notice both Z axis steppers get warm. So I started checking regularly and they are always warm if the printer is on. After a print and I don't retrieve it for a while (sleeping) and it all cools down, the Z steppers are still warm. X and Y steppers are always cool unless mid-print.
This morning I turned on the printer and the whispery whine was quite loud. Surprisingly loud, coming from Rambo. I gently touched the Rambo case to see if I could feel any vibrations and the door "settled" (micro-creak as it released some tension) and the sound stopped (back to quite whispery whine). Z steppers are still warm.
So I am wonder if the Rambo has a bad component, like switching regulator, that is allowing current to the Z steppers when they are supposed to be off. Or is this by design to hold up the X carriage from falling? I don't think that would be necessary.
Thanks for any help.
-- Jon
Respondido : 08/04/2017 4:19 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Do I have a bad Rambo board?
Z Steppers are always on.
What you are experiencing is quite normal.
Peter
Respondido : 08/04/2017 5:01 pm
JLTX
 JLTX
(@jltx)
Thanks for response. So I needn't worry.
Why are they always on? Is this to hold tension to keep X level?
-- Jon
Respondido : 08/04/2017 5:36 pm
AJS
 AJS
(@ajs)
Since the steppers don't know where they are in real space, they only count steps, you need some way of know where "home" is.
For X and Y, we have home switches, so it can always "home" before a print, and know where it is, so the PRUSA turns off the X and Y steppers. You can move those by hand, and it will re-home before a print.
There is no "Z" home function. The "calibrate Z" crashes the Z to to the top, and calls that zero. It then just counts from the last "calibrate Z" position. To prevent you from "bumping" the Z and having that calibration be incorrect, the PRUSA keeps Z energized, so it is harder to move - less likely to lose count.
A bad Z "zero" can be hazardous to the printer. if the head is lower than the software thinks, it will crash and scratch your bed. Also, if the two Z steppers get out of sync (one get's bumped higher than the other), your whole Z will be unlevel making your prints fail (bad first layer, or worse).
So it is in your best interest to keep Z active at all times, and to occasionally do the "Z calibration".
Hope that helps.
Respondido : 08/04/2017 6:26 pm
PJR
 PJR
(@pjr)
No. No. No.
"AutoHome" will home the Z at a distance of 0.15mm above the bed.
"Calibrate Z" gets you to raise the Z axis to the top Z end stops in order to ensure that both sides are level; from there it performs an "Auto Home" to set the Z axis as above.
The Z end stop is, of course, the induction probe which is used to detect the probe/bed distance.
Ideally, the Z axes should be moved to the top end-stops whenever the printer is turned on or power-cycled.
Peter
Respondido : 09/04/2017 1:32 pm
AJS
 AJS
(@ajs)
Peter
Peter
THANK YOU. You are correct. The dual Z steppers are kept powered to keep their relative alignment and prevent small bumps from harming that.
The PINDA helps set Z=0.
Thanks for correcting my thinking.
Respondido : 09/04/2017 5:29 pm
