Disappearing Menu Options
kevin.e2
(@kevin-e2)
Hello,
Having what I think are odd issues with my kit Mk2.
In short, I run a print, something goes wrong and I use the menu to stop the print. Upon stopping the extruder head moves up a little and backs off. So far so good.
I then go into the menu to move the Z axis up a bit so I can get at the nozzle to clean it, and there is no option to move Z. Just X, Y and the Extruder.
If I go to the Calibration menu, it has no options except to go back a level in the hierarchy. So I can't re-calibrate, auto-home or anything like that.
If I turn the printer off and on again, or press the rest button, those menu options return.
Is this normal behaviour, or is this indicating an issue?
When I'm done a few errands I'm going to give the beastie a once over, including electronics, but I thought I might ask about it and see if anyone has insight.
Cheers!
Kevin
Veröffentlicht : 31/12/2016 7:24 pm
Ancientwolf
(@ancientwolf)
Re: Disappearing Menu Options
Ive had it happen to me once too.
Yeah, its that guy... 3D Nexus
Veröffentlicht : 31/12/2016 10:10 pm
patrizio.b
(@patrizio-b)
There are plenty of bugs when you stop a print... i don't even use that option anymore, i just reset or turn off the printer as i find it way more reliable than using that option.
I suggest you to add your findings as "issues" on the firmware's github.
Veröffentlicht : 01/01/2017 2:53 pm
