Disabling buzzer for colorprint
Brandon Mott
(@brandon-mott)
When I recently used colorprint for the first time I realised that the buzzer that goes off to notify you that its time to change the filament keeps going off until you make the filament change. Is there a way to disable this so it either only goes of 3 times and then is done or to turn it off completely? If I were to run a colorprint overnight I'd rather not be woken up by my printer and I also know my school is getting a new MK2S this year and I'm sure they wouldn't like to have the buzzer keep going off during class.
Posted : 12/08/2017 4:14 pm
AJS
 AJS
(@ajs)
Re: Disabling buzzer for colorprint
You really don't want to leave the printer it it's change filament state for an extended period of time. If you are asleep when a change is needed, you need to wake up and change it. That is why it is so persistent with the buzzer.
The class room is a slightly different situation, as one person may be attending to the printer and not want to disturb the rest of the class.
I do no think this is a wise modification to make.
That said, if you edit the .gcode file and remove the buzzer command, it will be silent.
Posted : 12/08/2017 4:21 pm
Brandon Mott
(@brandon-mott)
What sort of issues would arise from leaving the printer in the filament change mode?
Posted : 12/08/2017 4:29 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
From the E3D web site:
Like all 3D printers, printers fitted with a high temperature all metal hotend can be a fire hazard. You are using experimental technology to heat and melt plastic, in a machine that you may have built or modified yourself, that likely does not have safety certification or significant failsafes. Fire/Smoke alarms, supervision of your printer while printing, and expertise should not be considered optional.
Peter
Posted : 12/08/2017 4:47 pm
Brandon Mott
(@brandon-mott)
During the filament change doesn't the printer turn off both the hotend and heated bed though? I thought I noticed the temperatures lowered while I was changing the filament.
Posted : 12/08/2017 4:54 pm
PJR
 PJR
(@pjr)
No
Peter
Posted : 12/08/2017 7:27 pm
