Changing power modes through Octoprint
[Fermé] Changing power modes through Octoprint
paul.m
(@paul-m)
Is it possible to change power modes on the MK2 through Octoprint? Meaning is there a gcode command that could be sent to the printer to change power modes or is it through the printers display only?
Thanks
Publié : 01/12/2016 9:10 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Changing power modes through Octoprint
M907:
case 907: // M907 Set digital trimpot motor current using axis codes.
#if defined(DIGIPOTSS_PIN) && DIGIPOTSS_PIN > -1
for(int i=0;i<NUM_AXIS;i++) if(code_seen(axis_codes[i])) digipot_current(i,code_value());
if(code_seen('B')) digipot_current(4,code_value());
if(code_seen('S')) for(int i=0;i<=4;i++) digipot_current(i,code_value());
#endif
#ifdef MOTOR_CURRENT_PWM_XY_PIN
if(code_seen('X')) digipot_current(0, code_value());
#endif
#ifdef MOTOR_CURRENT_PWM_Z_PIN
if(code_seen('Z')) digipot_current(1, code_value());
#endif
#ifdef MOTOR_CURRENT_PWM_E_PIN
if(code_seen('E')) digipot_current(2, code_value());
#endif
You can sent the required power setting based onthis:
// Motor Current settings for RAMBo mini PWM value = MotorCurrentSetting * 255 / range
#if MOTHERBOARD == 102 || MOTHERBOARD == 302
#define MOTOR_CURRENT_PWM_RANGE 2000
#define DEFAULT_PWM_MOTOR_CURRENT {270, 830, 450} // {XY,Z,E}
#define DEFAULT_PWM_MOTOR_CURRENT_LOUD {540, 830, 500} // {XY,Z,E}
#endif
Peter
Publié : 02/12/2016 5:54 pm
Carsten
(@carsten-2)
@Peter: Thanks for digging it out of the source!
So the code would be
M907 X270 Z830 E450
to "silence" mode? Did I got that right?
Carsten
My Prints: https://www.prusaprinters.org/social/15695-carsten/prints
My Employer: https://make-magazin.de
Publié : 03/12/2016 1:11 pm
PJR
 PJR
(@pjr)
Yes, that is correct.
It will remain until the RAMBo is reset/power cycled.
Peter
Publié : 03/12/2016 10:09 pm
Nigel
(@nigel)
Listen to Peter (PJR) I admit he is king of the G codes. I am learning.
Nigel
Publié : 05/12/2016 2:39 am
Carsten
(@carsten-2)
Tested and installed as two custom Buttons in octoprint. Good thing.
Carsten
Publié : 05/12/2016 10:02 am
Jippe
(@jippe)
How much current is too much for xy-steppers? High power setting is 540 but those steppers are rated 2x350mA? Can I put 700 without problems?
Publié : 14/02/2019 8:04 pm
