Change filament function?
Patrik Rosén
(@patrik-rosen)
Hi!
I'm printing some prices for my wifes bowling after work event tomorrow. Changed color to red, it worked great, but when I was about to change it back to white I loaded the new filament, but when it reached the spot where it was about to continue the print it just stopped...I waited for about 20 seconds before I raised the Z axis and removed my print to restart it, after a while it continued to print, mid air?
I had to choose "filament is not clear" three times when switching from red to white.. are there a timeout when using the change filament function?
Best Regards Patrik
Me on 3dhubs!
Me on MyMiniFactory!
Me on Instagram
3D Printing Live Feeds
Prusa MK2 Usergroup Slack Live Chat
Unofficial live chat by users for users.
Postato : 24/10/2016 7:27 pm
Patrik Rosén
(@patrik-rosen)
Re: Change filament function?
Reprinted!
Same problem again! This time I just choose "filament is not clear" one time instead of three times, but it still stopped when it reached the spot where it should continue... Gaaaah!
I wont touch it now...Lets see if it magically starts again 🙁
Me on 3dhubs!
Me on Instagram
Postato : 24/10/2016 9:25 pm
Patrik Rosén
(@patrik-rosen)
YES, it just started again! I did pause/resume the print from octoprint a few times, not sure if that helped
Me on 3dhubs!
Me on Instagram
Postato : 24/10/2016 9:27 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Patrik
Did you check out the Octoprint Terminal window. I have noticed that the M600 causes issues if you take too long (more than 3 beeps) to change the filament, even with the command in "long Running Commands" and an increased timeout.
Peter
Postato : 24/10/2016 10:38 pm
