Cannot calibrate- Z axis problems
thomas.g7
(@thomas-g7)
Z axis errors on i3mks2
I was wondering if any other user had a problem with the i3 mks2 printer. One day it would not print. The unit somehow lost it's calibraiton . I am having problems with my pre assembled Prusa. It would not print. - would stay at the max Z height and not move down.The printer would not print. It would not find the Z=0 level. I ran the Z calibration unsuccessfullly. I then got an error that the printer lost it's preset factory settings. I then re-ran the XYZ calibration. The printer failed the XYZ calibration. I consulted the manual and checked that the X ,Y and Z axis all move freely and are correctly aligned. They all passed. I then re-ran the X,Y.,Z calibration
As Blas suggested, I checked the operation of the Z sendor in the calibration>show endstops menu. I was able to have the Z sensor detech a metallic object. It successfully changed state from 0 to 1 and back to 0 as I swiped the metal object by the sensor.
I also checked the positon and tension to the PINDA cable. There seemed to be no obstructions or excessive tension present.
I did notice that after doing Z calibration the gantry would not move downward. The Z position detected was 0 even though the gantry was at the max height from the base. The only way I was able to get the gantry to move downward was to go into the settings>Live adjust Z and change the zero to a negative number. After doing this I exited the menu and was able to do a calibration. It successfullhyh measured the nine reference points. It then searched the four bed calibration points. but failed at the third point and said that bad calibration point was not found.
I them moved the Z axis about half way upwards as suggested. The Z height measured at Z = + 68 mm.
Other than reloading the firmware and drivers, does anyone else have any troubleshooting ideas?
Thanks
Tom
Napsal : 16/10/2017 12:38 am
AJS
 AJS
(@ajs)
Re: Cannot calibrate- Z axis problems
Tom,
I am not sure I followed all your trials and attempts, but here is some general advice people have found helpful.
1) If there is a firmware issue, a factory reset and then install the latest version seems to help.
2) The general calibration process found here:
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
can be helpful. If you try these steps, then explain what happened at each step (photos if possible) we can help focus better on your issues.
Napsal : 18/10/2017 3:01 am
