Can i expect more than this?
TTGeek
(@ttgeek)
Hi all
So i have a prusa i3 mk2s and have been printing on and off for half a year now. I'm trying to print part of a lamp screen. The wall is 1 mm thick.
I'm getting some layer shifting, i guess it is. Is this to be expected or can i do something about it?
https://drive.google.com/file/d/1hLgAJpfnZPMhnyqqEmWIDtargM14_ZpG/view?usp=drivesdk
https://drive.google.com/file/d/1pqeXpYhBjG6JFZ1p6GLngyu68L6kSHYs/view?usp=drivesdk
Veröffentlicht : 30/03/2018 4:31 pm
chad.j
(@chad-j)
Re: Can i expect more than this?
That is beyond out of whack. I have had my printer for as long on and off printing but it has no issue like that on walls as thin as 0.5mm thick. Try printing slower.
Veröffentlicht : 30/03/2018 6:54 pm
digibluh
(@digibluh)
that's pretty thin and probably moving around while it's prints and maybe more cooling? slower or a different orientation might help... hard to say. but i'm sure it could be way better than this.
Veröffentlicht : 30/03/2018 8:24 pm
can you use spiral vase mode?
[attachment=0]20180331_004153[1].jpg[/attachment][attachment=1]20180331_004204[1].jpg[/attachment]
this was printed in vase mode
with the external perimeter extresion with set at 1mm
and it came out at .97mm thick wall
regards joan
Veröffentlicht : 31/03/2018 1:51 am
TTGeek
(@ttgeek)
Thanks for replying. Doesent seem like slower makes much diff. I think ill try to replace sone x axis bearings. They are emitting ratteling noises.
Veröffentlicht : 31/03/2018 9:27 am
TTGeek
(@ttgeek)
Yes it moves a bit late in the print but not in the beginning. Cant do vase mode on this model.
I will try to tension the belts more and replace x axis bearings.
Thanks.
Veröffentlicht : 31/03/2018 9:34 am
Tim Brennan
(@tim-brennan)
Seems like belts are too loose perhaps.
Veröffentlicht : 31/03/2018 11:21 am
