Calibration XYZ after replacing the PEI sheet
claus-christian.u
(@claus-christian-u)
Hi, I’m using the firmware 3.1.0 and today I replaced the PEI sheet. But the calibration XYZ failed with the message: „XYZ calibration failed. Bed calibration point was not found.“. I tried it several times and had no success. But after that, I tried the next calibration for all 9 points and it worked well. Also the printing of the first layer worked fine. So is it only a error in the firmware?
What should I do? Nothing and go on?
Respondido : 06/01/2018 8:31 pm
Re: Calibration XYZ after replacing the PEI sheet
did you take the x carriage to the top and re ballance the z lead screws both times
sometimes calibration fails because the z lead screws are out of synch
regards joan
Respondido : 06/01/2018 8:50 pm
matthias.h2
(@matthias-h2)
Where are the Z lead screws??
Thankyou
Respondido : 13/01/2018 1:28 pm
richard.c12
(@richard-c12)
The vertical ones.
Respondido : 16/01/2018 10:15 am
