Calibration Fail
alex.s10
(@alex-s10)
Calibration Fail
When doing a Z level test it worked for the first 5 points then on the 6th and 7th point it pushes down heavily on the bed. This is with the sensor about as low as it can go. When I have the sensor where it should be it does this for all of the testing points. Ive watched the setup video and still cannot fix this issue.
Opublikowany : 17/08/2017 8:26 pm
AJS
 AJS
(@ajs)
Re: Calibration Fail
Sounds like you need to do a new XYZ calibration.
Opublikowany : 17/08/2017 11:29 pm
alex.s10
(@alex-s10)
I have and the same thing still happens.
Opublikowany : 17/08/2017 11:41 pm
AJS
 AJS
(@ajs)
It sounds like your PINDA sensor is too high. It is triggering at the first points, but not the last few. It should be approx 0.6mm higher than the tip of the nozzle (about the thickness of a credit card).
Try these steps:
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
If that does not help, please comment back here and we can see what we can figure out.
Opublikowany : 17/08/2017 11:54 pm
alex.s10
(@alex-s10)
Try these steps:
It works so far, but it keeps saying the distance between he nozzle and the bed is not set yet. How would i go about doing that?
Opublikowany : 19/08/2017 7:15 am
AJS
 AJS
(@ajs)
Try these steps:
Steps 3-5 set that value.
When you run the V2 calibration code that came with the machine, or the V4 Calibration file from the link, it executes a code command to clear that warning. The printer sets that warning when you do an XYZ cal since that zeros the Live Adjust Z value. The printer doesn't know you have or have not fixed that, it just knows you have not cleared the flag which either of those .gcode files will do.
Opublikowany : 19/08/2017 4:14 pm
