Bronzefill
joe.w
(@joe-w)
Bronzefill
The pre-configured slic3r settings for bronzefill are working well at 0.2 layer height but don't at 0.1. It clogs around the nozzle and fails to stick to the bed - even with glue stick applied.
The material is capable of printing at that resolution and I wondered what tips you could give me for adjusting the settings so it can print at 0.1. Lower print speed? Adjust flow rate? Any help greatly appreciated.
Respondido : 18/10/2016 12:05 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Bronzefill
Hi Joe
I print Bronzefill with a line width the same as the nozzle diameter (0.4mm) and quite slowly with slower retract speeds. At 0.1mm layers, 40mm/sec should work.
Peter
Respondido : 18/10/2016 12:29 pm
joe.w
(@joe-w)
Re: Bronzefill
Thanks Peter! I'm new to printing so is that 40 mms for all the elements - solid layers, infill etc?
What retract speed should I use?
Respondido : 18/10/2016 12:41 pm
PJR
 PJR
(@pjr)
Re: Bronzefill
Joe
I really can only advise what works for me; you may find a different solution. The most important think here I think is the line width. Then the speed - 40mm/s maximum, with perimeters slower, maybe 30mm/s. Retraction speed - try at 10 to 15mm/s initially.
Bronzefill does not like too much pressure, hence slow and gentle. It can be difficult and is still "experimental" and is therefore not ideal for those new to 3D printing.
Peter
Respondido : 18/10/2016 3:31 pm
joe.w
(@joe-w)
Re: Bronzefill
Really appreciate the advice - many thanks.
Respondido : 18/10/2016 4:31 pm
