Bed won't heat after failed print
So a print failed because the print started to curl up and hit the sensor.
Now the bed won't heat up. Any ideas on what could cause the bed to not heat?
thanks!
Veröffentlicht : 14/01/2017 9:21 am
Re: Bed won't heat after failed print
I should add:
-The red led at the print bed does not go on anymore
-There is not 12v at the print bed
-Continuity on the cable is OK
-About 1 ohm at the bed
-Thermistor seems to still be attached properly.
Veröffentlicht : 14/01/2017 10:01 pm
Check the 15A fuse on Mini-Rambo board
Veröffentlicht : 14/01/2017 10:44 pm
thanks, i checked all the fuses
Veröffentlicht : 15/01/2017 5:45 pm
Anything else I can try?
Veröffentlicht : 17/01/2017 4:23 am
Did you look at the connector for the heated bed ? The connectors melt. This is what happened to me.
Veröffentlicht : 26/01/2017 4:56 pm
