Bed play - how to solve it ?
itamar.b
(@itamar-b)
Hey,
I think the bed in my printer is not fully secured, I can wiggle it a bit from side to side and I think it's what's causing my prints to fail \ look really bad 😳
how would you secure it better ? tighten the bearing U bolts? 🙄
thanks
Opublikowany : 16/09/2017 4:07 pm
AJS
 AJS
(@ajs)
Re: Bed play - how to solve it ?
You really need to look while you wiggle it, and see what item has play in it. There is no way for us to see it from here.
Check to make sure each thing that should hold it secure has no play, and when you move the bed you should be able to see what is moving and what is not. It is that interface that is the problem.
Opublikowany : 16/09/2017 4:52 pm
