Bed not heating op i3 mk2
Hi, I am new here.
When slicing with S3D bed will not heat up.
With the original treefrog on the sd card it is working well.
I want to compare the treefrog g-code which came with the prusa SD card with my temp setting from S3D. Unfortunately I lost thee original sd card.
Can anyone provide met with the original g-code treefrog file which cam with the prusa i3 mk2 printer so I can test.
thanks
Opublikowany : 31/01/2017 4:47 pm
Re: Bed not heating op i3 mk2
All sample gcode files are part of drivers package. http://www.prusa3d.com/drivers/
There are working S3D profiles as well.
Opublikowany : 31/01/2017 5:07 pm
