Bad surface quality on supports
xerdo
(@xerdo)
My prints have had a number of issues with poor surface quality immediately above supports (and if I'm being honest, bridging too). I've had this problem since I first got the printer, but I generally haven't been printing things that require support or I've done post-processing to cover it up. Here's an example from the latest print I did:
And what it looked like on the bed:
Some details of this print:
0.2mm layer height
40mm/s print speed
PLA
215C first layer temp/210 after
60C bed temp
I've tried messing around with a few different settings like the ones detailed on Simplify3D's knowledge base, but have generally only had mixed results. I've even tried printing a modified nozzle fan guide (not this exact one since I can't find the one I made right now, but it's similar), although I've since removed it because it started warping a little.
My assumption is that this is probably some kind of cooling problem, though idk for sure. I'm considering trying to mount an extra fan like in this mod: https://www.thingiverse.com/thing:2342067 as my next step to see if that helps. It's worth noting that even though my print temp is 210 here I normally do 200 for other PLA - the stuff I printed the ocarina above with is eSun's PLA+ so it has some additional polyesters mixed in with it. The result is still the same with standard PLA unfortunately.
Is there anything else I try? I appreciate any suggestions 🙂
Postato : 29/06/2017 10:17 pm
Philip Garibaldi
(@philip-garibaldi)
Re: Bad surface quality on supports
Can you put a screenshot of the S3D support settings tab?
Philip G.
Original Prusa i3 MK2S
Turnigy Fabrikator Mini
Postato : 30/06/2017 2:49 pm
xerdo
(@xerdo)
Yeah here are my settings:
Postato : 01/07/2017 7:07 am
stefan.p3
(@stefan-p3)
Same problem here, sliced with slic3r, standard pla settings...
Reduced contact distance from 0.1 to 0.05 but the problem still persists... 🙁
I can't print overhangs 😥
Anyone had the same problem and fixed it?
Postato : 22/07/2017 12:17 am
AJS
 AJS
(@ajs)
If you want the supports to Pop Off, you need to increase the contact distance to 0.2mm 0.1mm is for dissolvable filament.
Postato : 22/07/2017 5:04 am
grmagnu24
(@grmagnu24)
Did you ever find a solution to this? I have the exact same issue, using Slic3r.
Postato : 18/10/2017 1:07 am
Martyn
(@martyn-2)
i also have this issue and would like to read any solution's available, thanks
Postato : 19/10/2017 8:11 pm
KennyB
(@kennyb)
Another here with this issue. Do most people just not use supports? I'm wondering if the water soluble supports might fair better with the smaller contact distance?
Postato : 20/11/2017 5:04 am
