Bad print quality when using supports - MK2S with Slic3r
grmagnu24
(@grmagnu24)
I've been using my MK2S for a few months and the print quality is great. However, I get strange print quality issues when using supports (in Slic3r). Additionally, the support layers are very inconsistent. See pictures in album below for some examples:
https://imgur.com/a/XA2Sj
I can't tell if this is an issue with my printer or with Slic3r. Does anyone know why this is happening?
Thanks!
Graham
Veröffentlicht : 21/10/2017 9:18 pm
AJS
 AJS
(@ajs)
Re: Bad print quality when using supports - MK2S with Slic3r
Please post your supports settings.
Veröffentlicht : 22/10/2017 1:28 am
grmagnu24
(@grmagnu24)
Here's my support settings:
https://imgur.com/a/jXb55
Thanks
Veröffentlicht : 22/10/2017 1:45 am
ggg
 ggg
(@ggg)
I have same prbolem and i dont use anymore support. Does not matter, quality is poor. This printer can not print arc's from the bottom to up. And bottom-up rings also do not know how to print. Ring come oval.
My solution is to cut the figure 2 or 4 pieces and then i glued together. Using support material is wasted time and plastic.
Veröffentlicht : 22/10/2017 10:47 pm
ggg
 ggg
(@ggg)
next print - https://imgur.com/a/nrmHt
Veröffentlicht : 23/10/2017 12:22 am
AJS
 AJS
(@ajs)
Try: Contact Z Distance 0.2mm, and increase the XY Separation to 1mm and 3 interface layers.
Veröffentlicht : 23/10/2017 2:16 am
ggg
 ggg
(@ggg)
i try (Contact Z Distance 0.2mm, and increase the XY Separation to 1mm and 3 interface layers.) and quality is very bad
Veröffentlicht : 23/10/2017 12:52 pm
AJS
 AJS
(@ajs)
What are your speed settings?
Veröffentlicht : 24/10/2017 2:53 am
ggg
 ggg
(@ggg)
speed is default 100%. changing the numbers does not change the quality, i have already tried a lot. this is probably the problem with printer drivers.
Veröffentlicht : 24/10/2017 10:39 am
