Anti vibration rubber
Did anyone of you found a method to reduce vibration sound from MK2 directly transmitted over the feet?
I am placing my MK2 into an IKEA case and the MK2 transmits the vibration.
Opublikowany : 12/07/2016 9:52 am
Re: Anti vibration rubber
Andreas
There are some printable AV feet here: http://www.prusa3d.com/prusa-i3-printable-parts/ You will also find a ggod selection on Thingiverse.
Peter
Opublikowany : 12/07/2016 10:37 am
HI Andreas,
I used a 55 × 55 cm (10 mm width) cork tile and it's doing a pretty good job, I lost ~10 dB.
I'm like Jon Snow, I know nothing.
Opublikowany : 12/07/2016 12:20 pm
