adding solid areas for better support
Hello, all.
Is it possible to specify a solid area within my model so that Slic3r doesn't use infill?
I have a model with some high stress points where a bolt will go through a 10mm rectangular part, and I'd like to create a 5mm solid circular area around the bolt hole to give it more rigidity.
Is this possible?
I use 123Design for modeling.
Thanks.
Veröffentlicht : 26/11/2017 5:27 am
Re: adding solid areas for better support
In slic3r, you may use the modifier meshes.
http://slic3r.org/blog/modifier-meshes
Veröffentlicht : 29/11/2017 8:33 pm
