A problem with z axis
LJC
 LJC
(@ljc)
I just started 3D printing about a week ago with a pre-assembled MK2S, it was working ok with a slightly warped heatbed. :s
Until yesterday after it finished a print, and I started another one, the nozzle height raised and it just stayed there and was printing in mid air... The only thing I changed was the live Z adjust from -0.437 to -0.422. The nozzle just doesn't get as low as it was before even tho I ran the calibration multiple times.
Please help
Thank you
Postato : 24/09/2017 9:37 am
Re: A problem with z axis
have you tried a factory reset and full recalibration?
if memory serves me well, a factory reset is performed by holding down the selector knob on the LCD Screen, turning on the power and waiting for a couple of seconds with the selector knob still pressed...
Postato : 24/09/2017 10:07 am
LJC
 LJC
(@ljc)
Just did a factory reset followed on page 27 in the manual, erased all data and recalibrate again, but the problem remains... It refused to go back.
The nozzle is about 2 mm above heatbed when Z is 0. 😕
Postato : 24/09/2017 12:53 pm
AJS
 AJS
(@ajs)
1) Have you done a new XYZ Cal?
2) Is it possible the PINDA probe got bumped and move up a few mm?
Try these steps:
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
Postato : 24/09/2017 2:20 pm
LJC
 LJC
(@ljc)
I did the calibration, y is perpendicular to x. Z just wouldn't lower itself like it did few days ago...
https://imgur.com/a/qief0
The image is when Z is at 0.15. I am sure that PINDA probe stays still, nothing changed physically I think.
Postato : 24/09/2017 4:28 pm
MNKid
(@mnkid)
Have you tried raising your pinda probe slightly? Sometimes it can start to loosen during prints and work its way down or up. If it has started to slide down just a tad then it would make the nozzle sit higher up. I would play with the pinda probe again and slightly (really slightly per time) and start calibrations again. if it looks terribly high during the calibration start again, just reset the printer, raise the pinda probe slightly again and repeat until you feel its close enough to calibrate WITHOUT it rubbing the bed and tweak from there. I suspect the pinda probe has shifted every so slighty but I am not sure. That's where I would start looking though.
Let us know if you find out what it is! Thanks. Good Luck.
Postato : 27/09/2017 5:38 am
LJC
 LJC
(@ljc)
I raised the PINDA probe and the nozzle can now touch the bed 😀 Should have done it at first... I was so ignorant and I apologize for that. Thanks for all the help.
However, I am having the inconsistent Live adjust Z now just like many others... I ran calibrate z(when bed was cool) → auto home → moved the nozzle to the centre of bed → put a piece of paper underneath and Live adjust Z → the distance from the nozzle to bed looked perfect (0.15).
I then did another auto home, moved the nozzle to the centre again, and found the nozzle raised back to where it was before adjusting(live adjust z value remained). It seems like auto mesh bed leveling, temperature of heatbed, auto home are all affecting the Z axis... The result of V2Calibration is quite wavy, and 75x75 grid is also not helping since z changes all the time.
What to do next?
Postato : 29/09/2017 3:23 pm
AJS
 AJS
(@ajs)
You should check if anything is moving. See if you can wiggle any of the parts or see if anything can move - not under motor power.
Postato : 29/09/2017 8:53 pm
MNKid
(@mnkid)
What to do next?
ok so you ran xyz calibration and then adjusted live z after? Ill write what I think you could do and hopefully it will help.
1. xyz calibration. Success, its all great!
2. Live adjust Z is at 0. Now print V2calibraion.gcode and modify to the desired value.
-If this wont produce consistent results, you can try to calibrate the PID calibration to the desired print temp. And re-run V2calibration.gcode
If your Z still seems very inconsistent, I would honestly look a the PINDA probe again. I found that for mine, even when the two screws where tight holding the pinda in place, I could still, rather easily, spin the probe. If your pinda seems easy to twist, I would find a way to get it to hold in place tighter. Even slight slight moves will cause it to have inconsistent z levels.
Postato : 30/09/2017 4:09 pm
tiago.d
(@tiago-d)
Try out the test square mentioned here instead of the V2 calibration code.
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/life-adjust-z-my-way-t2981-s150.html
You can get a better idea of how the first layer looks.
Also my Z adjust is at 1.430 as my PINDA seems a bit less sensitive than others. But my prints still turn out great.
Postato : 02/10/2017 5:35 am
tiago.d
(@tiago-d)
Try printing the test square in different parts of the bed als
Postato : 02/10/2017 10:22 am
AJS
 AJS
(@ajs)
Two hints from JeffJordan might help:
- have a look at the hyperfine bed levelling thread
- make sure your extruder is calibrated correct
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/hyperfine-bed-leveling--t4330-s110.html#p41311
Postato : 02/10/2017 3:10 pm
LJC
 LJC
(@ljc)
I checked the printer thoroughly this time and every part looked solid. However I switched from Slic3r to Cura and Z seemed to be lot more consistent(coincidence?) although the live z value was still lost upon homing or mesh bed leveling.
So what I do now: set live Z back to 0 before printing → preheat bed(mesh bed leveling is affected by temperature) → print via Cura → it mesh bed leveling before heating up nozzle → crank up Z to the value it requires(and sometimes it needs a bit fine tuning). → And it prints! Even though the results still have room for improvement, I am happy with the printer now 😀
Really appreciate all the helps! I think the hyperfine bed leveling is just what I need next. 😀
Postato : 02/10/2017 4:15 pm
