Mk2s mmu Pinda v2
john.m53
(@john-m53)
Mk2s mmu Pinda v2
Changed sensor and program change.And it ends the problems
Postato : 20/05/2018 1:53 am
zbrozek
(@zbrozek)
Re: Mk2s mmu Pinda v2
Could you elaborate a bit on what you did? I'm quite curious.
Postato : 24/05/2018 6:19 am
john.m53
(@john-m53)
I also changed the firmware and I put the new pinda
Postato : 26/05/2018 2:14 am
john.m53
(@john-m53)
Firmware
Postato : 26/05/2018 2:18 am
zbrozek
(@zbrozek)
TEMP_SENSOR_PINDA appears to be defined once (in the Configuration_prusa.h file) and never checked anywhere. I also see some changes in temperature.h (e.g., a commented-out reference to current_temperature_raw_pinda).
Are you sure you uploaded the right archive? It looks somewhat incomplete.
Postato : 26/05/2018 3:53 am
