Z-adjust not saved?
I've started to experience an new issue with my Mk2S MMU. I have to re-enter the live z-adjust for each print. I'll start a print and tune it to say -0.8 mm. When I start the next print I find i need to reduce it again by 0.8 (-1.6 mm). This cycle continues. Is there something missing in the firmware that it is not actually getting saved?
Opublikowany : 24/01/2018 9:08 pm
Re: Z-adjust not saved?
Make sure you have done the first level calibration either from the menu in the latest firmwar or via the v2_calibration file on the SD card. It will save after that.
Opublikowany : 25/01/2018 7:04 pm
Topic starter
answered:
Thanks. This makes sense. I'm guessing there must have been another firmware flash I had forgotten about and this over-wrote my existing calibration.
Opublikowany : 25/01/2018 7:28 pm
