Re: X-axis push thing too short?
I could be wrong but is it on backwards? on mine the side that you can see the belts loops on is on the rambo mini side not the power supply side, could you check that and post a picture?
Opublikowany : 17/11/2017 6:21 pm
try turning the power off and slowly move the axis over to the end stop and see if anything hits the X-axis before it can get to the end stop, I know I had a issue with the zip tires on the cable rap hitting the rambo control box and was stopping mine from getting to the and stop
Opublikowany : 17/11/2017 6:25 pm
Topic starter
answered:
I had to remove a little part of the spiral wrap.
Thanks.
Opublikowany : 19/11/2017 1:04 pm
glade I could help and that it was something simple 😀
Opublikowany : 19/11/2017 4:56 pm
Topic starter
answered:
Yeah, so do I.
But Multi material certainly adds to the learning curve. 🙂
Opublikowany : 19/11/2017 5:27 pm
