WRONG EXTRUDER WITH SIMPLIFY3D
abegines
(@abegines)
Today i'm trying to print with Simplify3d, but no material is extruded.
I've inspected the GCODE and everything seems to be ok.
I'm using extruder 3 (for my black filament) and the slicer issue the T2 command.
The first T2 (starting script) is executed properly but the second T2 (for tool change) starts to use extruder 2 instead of extruder 3.
And the printer's response is "T:1" instead of "T:2"
¿why? ¿can anybody help me?
Bellow is an extract of the debug for this print session:
Attached the full XCODE and DEBUG...
SENT: G1 Z0.200 F1002
SENT: T2
READ: ok
READ: ok
SENT: G1 X103.983 Y90.178 F4800
READ: ok
SENT: G1 E4.0000 F900
READ: ok
READ: echo:busy: processing
busy: processing
busy: processing
busy: processing
busy: processing
busy: processing
busy: processing
READ: echo:T:1
T:1
READ: ok
Saludos,
abc
Opublikowany : 26/12/2017 1:22 am
abegines
(@abegines)
Re: WRONG EXTRUDER WITH SIMPLIFY3D
For the note, when I print with Pronterface the SAME GCODE, all it's ok...
saludos,
abc
Opublikowany : 26/12/2017 1:33 am
