Where to get the new (!!!) printed parts
Martin Majewski
(@martin-majewski)
Hi there,
My case for the new extruder switch board broke and I want to print a new one. However, the provided stl files are for the old (large) switch PCB.
Where can I find the new one?
Best wishes,
Martin
-- www.martinmajewski.net --Printables:printables.com/@MartinMajewski
Thingiverse:thingiverse.com/MartinMajewski
BlueSky:martinmajewski.bsky.social
Respondido : 30/10/2017 11:09 pm
Martin Majewski
(@martin-majewski)
Re: Where to get the new (!!!) printed parts
I printed the old version of the switch case and it is definitely not suited for the smaller switch PCB, as the new PCB is much wider and uses the mounting holes of both, the case and the metal frame. On the old case these holes are too close to the case's walls.
Respondido : 31/10/2017 10:35 am
Jakub Dolezal
(@jakub-dolezal)
Miembro Admin
files are here https://github.com/prusa3d/Original-Prusa-i3/tree/Multi-Material-Upgrade/Printed-Parts/stl
Look for:
superswitch-case-v2.stl
superswitch-cover-v2.stl
Print them from ABS or PETG 😉
Assembly manuals
/ Knowledge Base
Respondido : 31/10/2017 12:52 pm
Martin Majewski
(@martin-majewski)
Thank you for the update.
However, I created my replica yesterday to continue working. Moreover, I changed the design a little bit to make it easier to pack all the cables into the casing.
You can find my version here:
https://www.thingiverse.com/thing:2617048
Feel also free to use it as you wish (respecting the licensing, of course). 🙂
Respondido : 31/10/2017 5:03 pm
