the teflon tube in the extruder came out
Smiely
(@smiely)
Hi All
I am having a bit of trouble with one of the MMU extruders', don't know why but when loading extruder 1 the filament jams just after the hubed gear, i removed the festo on top of the extruder and tried to push the filament with my hand to see where the problem is and the teflon tube inside the extruder came out, i can put it back again but filament will not go through this extruder, any advise. any one had this issue before
Keep on smiling -
Opublikowany : 26/09/2017 2:26 pm
Smiely
(@smiely)
Re: the teflon tube in the extruder came out
No One, i really need help i can not print multi material as this is the first extruder
Keep on smiling -
Opublikowany : 02/10/2017 2:39 am
AJS
 AJS
(@ajs)
Very hard to see what is going on, without a photo.
Opublikowany : 02/10/2017 3:59 am
