Temperature in gcode
bainville.a
(@bainville-a)
First sorry for my English.
I begin to use my MultiMatrial kit and try to make a part of ABS supported by PLA.
However my question is the same with ABS + Verbatim BVOH or other.
In the Gcode generates by Slic3r I see this at the start (... to replace many lines for the sake of sanity ) :
; generated by Slic3r 1.37.1-prusa3d-win64 on 2017-11-12 at 19:28:07
; Start G-Code sequence START
T0
M104 S260 ; set extruder temp
M140 S105 ; set bed temp
M190 S105 ; wait for bed temp
M109 S260 ; wait for extruder temp
T0
; CP PRIMING START
M220 S100
G1 X5.000 F7200
M907 E750
T0
M220 S100
G4 S0
; CP TOOLCHANGE LOAD
G1 Y2.200 F7200
; CP TOOLCHANGE UNLOAD
M104 S260
G4 S0
G1 X65.000 Y0.000 F7200
T3
M220 S100
G4 S0
M907 E550
; CP TOOLCHANGE WIPE
; CP PRIMING END
We see T0 and T3 for the change to the Extruder 0 and 3 the issue I have concern the temperature.
At the start we can see that :
if i undestand correctly the begin with 260°C in extruder and 105°C on bed.
When we select extruder T0 the temperature is correct (260/105).
But when we select the T3 extruder I can't see any M104 and/or M140 command then... my PLA gonna burn...
Can anybody point me what I don't understand ?
You can reproduce this gcode file simply in slic3r :
  • Select 0.20 NORMAL WITH SOLUBLE FULL
  • Select for extruder 1 ABS and for extruder 4 PLA
  • Add whatever part you want that need support
  • Slice and export gcode (line 0 to 142 is what i talk)
  • Thank you.
    Respondido : 12/11/2017 11:38 pm
    bainville.a
    (@bainville-a)
    Re: Temperature in gcode
    Alright, it seems that an bug of Slic3r prusa edition 1.37.1, you can update to 1.37.2 for this.
    The Link : https://github.com/prusa3d/Slic3r/releases/tag/version_1.37.2
    Respondido : 13/11/2017 7:23 am
    PJR
     PJR
    (@pjr)
    Antient Member Moderator
    I think you will have problems when the temperatures are so different.
    The MMU will only work properly with materials which have similar temperatures (maximum difference is about 15 degrees).
    Peter
    Respondido : 13/11/2017 8:45 am
