[Chiuso] Stringing on MM
Pagina 1 / 2
daniel.t5
(@daniel-t5)
Stringing on MM
Over the weekend I upgraded my mk2S with the 4x Multi Material kit, and now I am having a real problem with stringing.
I am using the new Prusa Edition of Slic3r to slice, I've tried fiddling with temperature, didn't seem to do anything, I increased the retraction from the default in Slic3r (4) to 5, since I saw someone saying that a range of 4-5 will be required, and it did seem like it helped, but then it seemed to clog and my print failed. I had read that would probably happen, but I needed to try for myself.
I have this problem even when printing in single mode.
I did not have any issues with stringing before performing the upgrade.
Any suggestions on how I can improve this?
For what it's worth, the overall quality of my prints have seemed to go down since upgrading, but I'm trying to tackle one issue at a time.
Thanks!
Postato : 18/09/2017 5:21 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Stringing on MM
There are a few ways to overcome stringing, the main ones being retraction and temperature.
What material are you printing and what temperatures are you using?
Peter
Postato : 18/09/2017 6:09 pm
daniel.t5
(@daniel-t5)
Re: Stringing on MM
I'm printing PLA, and I've tried as low as 180, and as high as 220 and seen roughly the same amount of stringing.
Postato : 18/09/2017 7:06 pm
PJR
 PJR
(@pjr)
Re: Stringing on MM
In that case, there's another issue happening elsewhere.
Can you slice a model using E1 and E2, both PLA at 200 degrees with 4mm retraction, zip up the G-code and upload it for me to have a look at.
Thanks
Peter
Postato : 18/09/2017 7:37 pm
ir_fuel
(@ir_fuel)
Re: Stringing on MM
Same problem here, and it's independent of the used extruder. I use Slic3r Prusa MMU edition and use the default settings. Currently running a print with the Prusa grey PLA and it also has stringing, so it's not because of incompatible filament. Really hesitant to start playing around with retraction settings as I read on the forums that that can lead to blockages?
I'm just printing using 1 extruder btw. No multicolor prints right now. No use overcomplicating stuff if the basis doesn't work right.
I bought this kit not for colors but to be able to print with PVA and PLA at the same time, but I wonder if I'll manage to get this working decently ... The direct drive single extruder mk2s worked flawlessly. Seems that since I went to MMU it all went downhill. First print quality issues (other thread ...), now this.
Hopefully I can get my CR-10S first layer as good as on the Prusa, then at least I have a "quality" 3d printer that works while tinkering with this one (same filament on the CR-10S and same extruder temp gives zero stringing). Too bad the CR-10S isn't direct drive.
Postato : 18/11/2017 1:27 pm
ir_fuel
(@ir_fuel)
Re: Stringing on MM
btw @PJR, amazing how much time and effort you put in this forum. I hope Prusa recognizes this and gives you some compensation for helping their customer base.
Postato : 18/11/2017 1:28 pm
PJR
 PJR
(@pjr)
Re: Stringing on MM
Thanks.
I really don't want anything from anyone - don't want to feel obliged to do this. I just with I could get some assistance from PR on occasion. 😥
Peter
Postato : 18/11/2017 6:03 pm
PJR
 PJR
(@pjr)
Re: Stringing on MM
I have 2 Mk2/s + MMU printers. Strangely they require different filament retraction settings - one 1mm less than the other. I get blockages if I mix them up.
For me, stringing depends on temperature, retraction speed, retraction distance, layer height and filament colour/manufacturer. It really is a matter of getting everything tuned in. And maybe implementing Linear Advance which should allow retraction distance to be halved.
Peter
Postato : 18/11/2017 6:07 pm
ir_fuel
(@ir_fuel)
Re: Stringing on MM
Any idea what the best way forward is to find out what's going on?
I did a PETG print with an endoscope cam installed on my printer and what I saw there was that while printing sometimes small globs of PETG would come out of the nozzle and go to the side instead of going down to the layer. Then a while later this glob either falls off or gets picked up somehow and that of course causes "dirt" in the print. This is not related to a first layer/bed level/z height issue as this also happens when printing a layer at let's say 5mm height. I tried cleaning the nozzle and hotend but it was all ok, and my next print using PLA had stringing again too.
I managed to get a bit less stringing on PETG by setting the extrusion multiplier to 0.8, but isn't that extremely low already?
Anyway, both PETG and PLA string, and with the PLA I ran the exact same spool on another printer and there it doesn't string.
Postato : 20/11/2017 12:22 pm
PJR
 PJR
(@pjr)
Re: Stringing on MM
PET is more likely to blob and string than PLA; let's get PLA sorted first and then move on.
1. Install a sock (will help PET blobs)
2. Slice a model, zip up the G-code and attach to a post so I can see what is happening.
Peter
Postato : 20/11/2017 1:56 pm
ir_fuel
(@ir_fuel)
Re: Stringing on MM
Well, guess what ... after doing the PETG print and the cleaning and more PETG, now back to my orange PLA.
Stringing is a lot less than before. There still are some but it's like 5% of what it used to be.
BTW what is that sock thing you talked about? Never heard of it.
Postato : 20/11/2017 5:40 pm
PJR
 PJR
(@pjr)
Re: Stringing on MM
Socks: https://e3d-online.com/v6-socks-pro-pack-of-3
These are better than the new type; they cover the nozzle so nothing sticks.
Peter
Postato : 20/11/2017 6:44 pm
ir_fuel
(@ir_fuel)
Re: Stringing on MM
Thanks.
Just ordered a set.
Postato : 20/11/2017 7:24 pm
ir_fuel
(@ir_fuel)
Re: Stringing on MM
I suppose playing with linear advance might also help?
Postato : 20/11/2017 11:12 pm
PJR
 PJR
(@pjr)
Re: Stringing on MM
Theoretically it should.
Peter
Postato : 21/11/2017 10:02 am
Vojtěch Bubník
(@vojtech-bubnik)
Utenti Admin
Re: Stringing on MM
Jindra, our print expert noted: linear advance will help reduce stringing, though the linear advance values are excessive on the bowden MM setup.
Postato : 29/11/2017 8:56 pm
DaveinMI
(@daveinmi)
Re: Stringing on MM
Seems I too have started having string in MMU single extruder prints. Printing the same models as before MMU. I've tried 5 c less in temp, which didn't help. I'm wondering if the default 4 mm retraction is too much ? Seems it was only 1 mm in the pre MMU slicer. Any thoughts ? Thanks !
Postato : 30/11/2017 3:20 pm
Vojtěch Bubník
(@vojtech-bubnik)
Utenti Admin
Re: Stringing on MM
The retract value is to relieve the pressure built up in the nozzle. Due to the slack in the bowden tubes, the retract for a MM setup needs to be much higher than on a non MM setup. The slack in the bowden tubes is nothing specific to Prusa printers.
Postato : 30/11/2017 3:39 pm
mavu
 mavu
(@mavu)
Re: Stringing on MM
Did you try capricorn tubes in house?
Do they actually help to reduce the needed retraction?
Postato : 01/12/2017 9:02 am
Vojtěch Bubník
(@vojtech-bubnik)
Utenti Admin
Re: Stringing on MM
I know that the capricorn tubes are on order. I am not sure whether they arrived, we are currently all busy with rolling out the MK3.
Postato : 01/12/2017 9:25 am
Pagina 1 / 2
