Spool holder above printer?
Does anyone have designs/solutions for placing the spool holder above the printer (say, on a shelf)? The relatively tight angle that you might get in feeding filament below the steppers likely won't be good in this. Different ways of mounting the extruder steppers would be ideal so the inlet would be level or above the frame. Does it exist?
Opublikowany : 18/10/2017 4:38 pm
