Slic3r Prusa Edition - Benchy Hull Disapearing
jonathan.l2
(@jonathan-l2)
i3 Experts,
I'm having an issue with the Prusa edition of Slic3r, that I can't seem to wrap my head around. Basically, this only appears to happen with the multi material benchy, from what I've seen so far... But once I have all the parts loaded, the gcode for the hull just goes away.
It doesn't matter what extruder I assign for this, even if I use the same extruder for all pieces, the same outcome always happens. This is only for the benchy, I have sliced other multi-color models from thingiverse without any issues.
Pictures can do a ton better job than I in showing what's happening. Would you guys happen to have any ideas? My fleet of single-color ships needs a multi-color brother. 🙂 I've attached both pics (AllPartsLoaded, is the "3D view" tab, while I hit preview to show what's happening in "MissingHull").
Veröffentlicht : 09/07/2017 8:10 am
Jakub Dolezal
(@jakub-dolezal)
Mitglied Admin
Re: Slic3r Prusa Edition - Benchy Hull Disapearing
Hi Jonathan,
can you please post, which version are you using? Also please try the newest stable Slic3r included in drivers package http://www.prusa3d.com/drivers
For advanced users, there is also GitHub with the latest release: https://github.com/prusa3d/Slic3r/releases
Let me know 😉
Assembly manuals
/ Knowledge Base
Veröffentlicht : 18/07/2017 9:33 am
jonathan.l2
(@jonathan-l2)
Afirm. It's the latest package from Prusa. - just downloaded it again to make sure.
The Slic3r version is 1.325.5.16
Unfortunately, it's still doing it. It may have something to do with the "M" that's getting put in all the prints.
Veröffentlicht : 23/07/2017 5:58 am
Jakub Dolezal
(@jakub-dolezal)
Mitglied Admin
Hi Jonathan,
are you using Benchy files for Multi Material provided by us? If not, please try them. (They are in the drivers package)
Also what kind of operating system and hardware are you using?
Thanks
Assembly manuals
/ Knowledge Base
Veröffentlicht : 23/07/2017 3:56 pm
jonathan.l2
(@jonathan-l2)
No sir, was not using the provided model, but the thingiverse link.
The download for drivers is just an executable, can you please let me know where it dumps example files? Browsing through the tree, I'm not seeing anything. I'd love to give your version a try.
Thanks.
Veröffentlicht : 24/07/2017 1:50 pm
