Slic3r PE MM Temperature Bug
Colin
(@colin-4)
There seems to be a bug present when using different temperatures for different filaments in Slic3r PE. I was printing with PVA interface layers, with PVA in extruder 4 set to 190. PLA was in extruder 1 at 205. The machine did its warmup but then printed the entire first layer at 190 regardless of which material was extruding. There was also a Facebook post which described pretty much the same thing.
Is this a known bug?
Respondido : 30/09/2017 2:34 pm
Smiely
(@smiely)
Re: Slic3r PE MM Temperature Bug
Had the same issue, it is a bug for sure
Keep on smiling -
Respondido : 02/10/2017 2:41 am
Colin
(@colin-4)
I reported it on the Prusa Slic3r Github. Hopefully they can get it fixed.
Respondido : 02/10/2017 2:43 am
Vojtěch Bubník
(@vojtech-bubnik)
Miembro Admin
This is a slic3r issue, which is being worked on.
https://github.com/prusa3d/Slic3r/issues/533
Respondido : 04/10/2017 2:19 pm
Colin
(@colin-4)
That's me. 😀 I haven't had a chance to try it yet.
--Colin
Respondido : 04/10/2017 2:41 pm
