Slic3r MM problem
I posted a slic3r MM problem on software forum, but thought I'd link to it in the MM forum as well in case someone has encountered this before:
https://shop.prusa3d.com/forum/software-f13/slic3r-mm-problem-t5538.html
Any idea what the problem is?
Napsal : 16/08/2017 9:01 pm
Re: Slic3r MM problem
This is not properly made model. Parts are overlapping, thats the problem.
This is an example, how cylinder part should look like.
Napsal : 16/08/2017 9:36 pm
Topic starter
answered:
I see now, weird how the other text works fine. That threw me. In Fusion 360 it's a 2-step procedure, first a 'cut', then reselect the sketch parts and press-pull 'new component' or 'new body'. Thanks!
Napsal : 16/08/2017 10:23 pm
