Slic3r 1.34.1.24 - Prusa Edition (Beta)
Jakub Dolezal
(@jakub-dolezal)
Member Admin
UPDATE This version is replaced by 1.36.2 stable, more here: http://shop.prusa3d.com/forum/original-prusa-i3-mk2-multimaterial-f26/drivers-1-8-0-with-slic3r-prusa-edition-t5859.html
!!! Warning: Installing beta version is for advanced users. Please note you are installing the software on your own risk !!!
Hi guys,
another beta is out! This time the main focus is on Multi Material print! We are working on soluble support and much more. Also, Vojtech ported the G-code generator from Perl to C++, resulting in improved performance of the MotionPlanner.
Changelog and download links:
https://github.com/prusa3d/Slic3r/releases
Don't forget to download Multi Material settings:
https://github.com/prusa3d/Slic3r-settings/tree/master/Slic3r%20settings%20MK2/printer
Issues please post here:
https://github.com/prusa3d/Slic3r-settings/issues
Happy slicing!
Assembly manuals
/ Knowledge Base
Opublikowany : 22/05/2017 6:37 pm
Kolous
(@kolous)
Re: Slic3r 1.34.1.24 - Prusa Edition (Beta)
How does work wipe tower in version 1.35.2? When I check Wipe towek enabled and leave default parameters the tower is not generated during slicing. Using 4 PLA materials and aded the tower later via post processor.
Opublikowany : 10/06/2017 9:27 am
PJR
 PJR
(@pjr)
Antient Member Moderator
This is what Vojtech wrote (it works for me):
For the integrated wipe tower to work, the following parameters need to be set correctly:
- single_extruder_multi_material has to be enabled at the Printer settings (next to the number of extruders).
- filament_type at each filament has to be set correctly to PLA, ABS, PVA or SCAFF (at the Advanced page).
- Wipe tower has to be enabled at the Print settings (Multiple Extruders page)
- The initial extruder has to be set correctly in the start G-code (at the Printer Settings, Custom G-code, Start G-code). Replace T99 with T[initial_extruder]. This now allows to print single color prints just by assigning an extruder to the object.
Peter
Opublikowany : 10/06/2017 9:56 am
Kolous
(@kolous)
Thank a lot! I was missing single_extruder_multi_material option.
Opublikowany : 10/06/2017 10:09 am
