Print Shifting
alexander.b19
(@alexander-b19)
Print Shifting
Hello!
We currently purchased a Prusa MK2 with a MM upgrade. While testing it during a multi color print coming back the next day I saw that there was a large shift in the print. Does anyone know why this would happen and how to prevent it?
Here are the photos!
https://imgur.com/wffkipO
https://imgur.com/7sEy5Lv
Best,
Alexander
Respondido : 01/11/2017 5:34 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Print Shifting
Please post your pictures on this forum. I (and a few others) will not look at image hosting sites.
Layer shifts are well covered in the main forums (the causes are the same for single and MMU). Do a forum search and you will find many solutions.
Peter
Respondido : 01/11/2017 8:55 pm
AJS
 AJS
(@ajs)
Re: Print Shifting
A number of common causes of a layer shift can be found in this post:
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
I would start by checking your Y belt.
Respondido : 05/11/2017 12:29 am
